Leaking Coolant From HERE
turbo
Fort Collins, CO
Not quite sure what this is, but it's where all the coolant is escaping. Can you help? (No, not the water pump, the water channel thing ABOVE the water pump, tucked up under the alternator.) :freak3:
TwoBobsKJ
Northern Ohio
Hmmm, if it's not actually coming out from the water pump gasket and spraying upwards then it looks like the water jacket may have a crack in it.
Did you badly overheat it recently?
