Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I used your instructions to remove floor console.Cut hole for flashlight base using measurement from Journey.The charger base is a little wider than the console so ground off about .25" each side and used propane torch to melt smooth.Ign.switched power from a wire to shifter.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
