Just found out about the KK strut fork/clevis mod.
KJ604
Vancouver BC
Since the KK strut fork/clevis should bolt on, this means it should also work with OME suspension correct?
Why is this mod not talked about more?
rjkj2005
US
Because of the price. Time you by both sides. I've been quoted $70 a piece. Well ti e you by 2. Your not that far from the price of a set of OME springs. So why spend that much for an inch when for $30 more you can get a good set of lift springs.
Only one year works
Plus they are a slightly different width
Plus price no reason to buy them when you can do a clevis for free and add a top plate and done
Funny how all of a sudden its like a new idea :icon_lol:
KJ604
Vancouver BC
honestly tomm I respect your opinions it seems like you have worked on quite a few of these rigs from what i have read. I was just surprised because another member just mentioned it to me but i havent read anything about it since ive been on these forums. i was only wondering if there was a reason people dont do it.
u2slow
BC
Your logic makes sense if somebody would comp the freight and take CDN$ at par..... but I haven't seen a vendor offering that yet.
Good used struts w/ KK forks were $95 CDN each from a local wrecker.
CzarKJ
Townsend, MA
I'm going to a pick and pull in the upcoming months. I'll see what I can find and if there are extras I'll share them here ;)
rjkj2005
US
Only one year works
Tom. Why only one year? Doesn't the 08 thru 11 use the same setup on both the liberty's and nitro's. As well as share the same shock, springs, and top mount with the kj's?
u2slow
BC
The other KK fork/clevis I've seen in pics were stamped steel.
The 2008 ones I picked up happen to be cast. The width is the same as KJ where it bolts to the bushing... and the same where it meets the strut.
Mine are in, along with 3 conduit nuts. I needed the extra length to make my 3/4" cradle drop work. :gr_grin:
Correct, they changed the design, way they were made after 08
3/4 inch cradle drop so what did you do with the UCAs?
So KK clevis and clevis :blah:
u2slow
BC
I wasn't about to stack 6 or 7 conduit nuts in there... so the KK one let me use 3 like everybody else does.
I remounted the balljoint under the UCA, instead of top-down. Angles are dandy. (Alignment shop adjusted my driveway job less than 1°.) I should be in good shape to go up another inch or so when I decide to stuff in some new CRD coils.
CRD coils will not really give you more lift
Still limited to amount you can go due to tie rod angles etc
Seen a lot try over the years but there are many limiting factors if you want to keep it a DD and be safe
JasonJ
Michigan
Pinion angle comes to mind as well.
if you get any lift from the diesel springs it's simply because they're stiffer, not because they're longer. keep that in mind, as it'll ride rougher.
