has anyone made a list of what stock Jeep wheels will fit on a kj? as in ones from a tj, jk, etc.? i know there are 2 different 5 lug bolt hole patterns. but I'm certain other Jeep vehicle wheels will fit. I really do not want some flashy chrome or solid black aftermarket wheels. I am basically looking for something close to home for around $75-125 for a set of wheels. I don't even care if the rim diameter is the same as long as they fit. as I would buy a new set of tires to get the dry pavement tires off my Liberty for off road / winter driving. honestly, my favorite wheels are 5 spokes from a Grand Cherokee. but i do not know if they will fit or not.
Tj wheels wheels will fit, zj 16 in will fit,basically if they have the 5x4.5 lug pattern your good..alot of guys run the 16 in moabs of tj rubicon, I personally found some 05 liberty wheels to use on my 03, I like the stock wheel look
WK Grands do not fit, earlier years of Grands work if 16 inch most all 15 inch Jeep wheels do not fit due to clearance issues with calipers Moabs work if lifted , but stock KJ/KK will both work of course
Anything with the 4.5" x 5 lug pattern and bore of 71.5mm will physically fit but not sure on the correct offset. 16" wheels from TJ wrangler rubicons are probably the best upgrade over stock. Btw, stock 16" alloy wheel weight is pretty good at 21lbs, steel wheel weight is only a pound or so away from that at 22-23. So IMO, the best upgrade over stock alloys would be the OEM steel wheels.
mercdudecbr600, Can you explain to me how a heavier, more difficult to balance and softer wheel would be an upgrade from stock alloys?
