Jeep Liberty Electric Supercharger?
JLRockies
Draper, UT
These things gave been popping up on enthusiast forums since the 90s. It's a leaf blower and not a very good one.
Neb1373
Louisville, KY
Although a lot better than some of the computer fan "superchargers" I have seen, you think about it you would need to pump a LOT of air, just to keep up with the intake.
If you fall for that I got some ocean front beach property to sell you back in South Dakota for cheap.
Not even remotely possible to do with a small setup like that.The RPM's needed to add 1psi of boost would require more amps then your alternator and battery can supply together.
JLRockies
Draper, UT
It's right up there with Nigerian royalty that need to deposit cash into your account for a little while.
Okura_hubby
north carolina
I think a forced/cold air intake to your airbox would be better than a electrical fan. And you can fab one for $10.
Speaking of electric fan, I was thinking of putting a push Rad Fan in front of the Radiator and tie together with the pull fan. I think it would benefit for stop/go/gridlock type traffic where forward momentom is not happening. My 63 Falcon doesnt handle stop/go trafic well, need to make a better fan cage and put some push fans on it. But holding off til I get back from Korea. Totaly off the targer. Sorry guys..
theroofable
It will be after global warming!
JeepinJarhead03
Petersburg VA
if you wanna get ridiculous - be ridiculous :p
ratchet strap your backpack leaf blower to the hood, and pipe it through a hole in the fender (word of advice.. anticipate a snorkel in the future and put the hole there..) run a bicycle handbrake cable from the backpack leaf blower into the jeep and have at it
at least when you're done goofin off and scaring everyone in your town you won't be out of any money :p
then spend the money on a snork and call it a day
JeepinJarhead03
Petersburg VA
Current Draw - Idle 1.5 Amps
Current Draw - Acceleration 350 Amps
Current Draw - Steady State 220 Amps
better put that booster in conjunction with the "waste to watts" doohicky they're designing too
all for saving CO2 .. at the expense of how many fragged batteries ?
Okura_hubby
north carolina
Vs using the Battery Powered blower, why not get one of those belt driven blowers that is used on older Mustang's that do a blow-through the carberator. Then just replace the duct and airbox for it to blow right into the throttlebody. with something custom fab'd duct work.. But I suspect your boost will probably damage your pistons. Talk on other thread about the engine cant handle much. But the leaf blower is a joke, probably no more gain than a forced air scoop to bring in true cold air.
JeepinJarhead03
Petersburg VA
and if it's an actual leaf blower.. think of all the dog hair and crap your spitting out with it :p
my lil backpack leaf blower comment was a joke, however I have seen someone try it.. for the life of me I can't remember who or where it was or what ended up happening
pretty sure it was at pendleton
