Jeep kj
Charliemartin
I have 2004 Jeep 2.7crd
I have no wipers radio or cigarette lighter I’ve checked all fuses
Swapped relays around and have check some earth cables
I’m in desperate need as all we have in rain in uk and can’t use veichle
Unclebob9
Ca.
In the good old days with my 66 GTO, this would happen, there was a problem with the electrical connection where it went from the engine compartment to the cockpit. I would wiggle and push the wiring harness from the engine compartment where it goes through the fire wall and it would work fine for months before it happened again. May not help, but worth a try.
blackhawk
Venezuela
You need a scanner with actuators to check if pcm is getting the order from multifunction wiper switch
