Jack Tip
Gentleman
8' Below Sea Level
Thought I would pass this on for WIW, it happened to me today, for the first time I had you use my jack and when I went to remove it the retaining bolt was so tight I could not turn it, had to find someplace to borrow a pair of channel locks and after a few hard turns it loosened, you may want to check yours before you have the same problem as I had.
especko
Kaukauna,WI
a couple months ago i used the stock bottle jack for the first time since i bought the jeep. it was also hard to turn but i was still able to get it out without needing any tools.
Thanks for the info. That's good to know so I'll check mine.
Thanks
ENBr
Scotland
I agree - it's worth a loosen before you're stuck in the middle of nowhere with no jack.
Anyone here use a high lift jack?
Ok, I checked mine and it was ok so the gorilla that puts them in at the factory must have had the day off when mine was made.....
EBNr....No I have not used a high-lift jack but you need a spot to put it on - like rock rails or steel bumpers mounted to the frame or something real solid I think that will get the long part away from the Jeep body.
Cant you get the jack out if that stupid plastic thing is still in there? I thought mine was stuck one time and I had to get it all out while it was still in there? :-s
especko
Kaukauna,WI
you probably could so how.
A BFH comes in handy sometimes......................
