Jack,Scissor,Bottle,HighLift or What?
I would like to hear from those who are lifted and that have actually had to change a tire. What jack is recommended on the trail?
The stock KJ scissor looks real weak. It should be noted that in my sedan I have a real 5000lb scissor jack with a flat top, 2x3 inch plate, that goes to 26 inches, would that do?
Here is a similar scissor: 20 inch http://www.northerntool.com/shop/tools/product_200305251_200305251
That jack doubles to lift the boat on trailer, does well. Getting some 2x10 inch thick wooden blocks is next as well.
SO what should I buy for the KJ? 4 ton bottle jack?
I suppose a high lift is out of the question without an adapter or rock rails.
LibertyFever
New Brunswick, Canada
Well on a lifted Libby you could get away with using the stock scissor lift jack with a couple of blocks of wood but only on flat ground or pavement.
A Hi-Lift would be a good idea too if only you had a point to jack from. You can't use the stock bumpers. Plus the length of the Hi-Lift can be a problem like where to stow it.
A bottle jack with a couple of wide blocks of wood would do well. Stows easily & very flexible.
diyman
Venezuela
for the TJ I have a bottle jack and some 2X6 blocks of wood
I have changed a tire before on the trail
2x to the above! :)
I'd also use the strongest bottle jack that still fits under the chassis / axle ( 6-8 t maybe? )
Don't forget a rag, only rocks are allowed to scratch the underbody :D
paullgj
Brownsville, Texas
Where place bottle jack for front end?
OK, bottle jack is easy for the rear - under the axle. But where is the jacking point for the front without doing damage to the underbody?
Thanks.
Gene
diyman
Venezuela
Thanks.
Gene
KJ's chassis has a mark to let You know..... Anyway, as a rule of thumb, near/below welding points...
Again, use a rag or wooden block, but beware, this might crack and split open...happened to me once :favorites68:
LibertyFever
I helped a buddy jack up his YJ to open his front diff with a small bottle jack last weekend. We improvised and used a shovel beneath the bottle jack so it wouldn't disappear into the snow.
More votes above for a bottle jack. The problem with bottle jack is that you need to stack enough wood as the lift of these type of jacks vary.(shovel wow) If I go this route a 2x3" rectangular steel plate would help for lifting front of kJ with wood.
Trying to find one with a moulded case that has 8 inches of lift.
Know of any good ones with a moulded case?
yellocoyote
NW Chicagoland
I use the hi-lift, but I also have a lift point (rock rails). If not for that, I'd likely use the bottle jack w/wood method.
Jayme, you must carry then stands as well. My caution over high lifts are keeping low and maintaining balance with those jacks. Your lifting point is then the rock rail front or rear?
I may eventually install the rock rails. I have a place to mount the HL jack onto the basket now. Just a lot of extra weight with the HL jack though too.
Still searching to find a decent bottle jack with a plastic carry case...(for now)
Banditsteve
North Yorkshire. UK
Wow! Can't believe you guys have a scissor jack! Mine (2002 Sport) comes with a bottle jack and wheel brace (lug nut remover) and extension poles etc all clipped into a plastic holder that bolts down under the rear passenger seat. Maybe you could see if your dealer can get one of those for you? I assume it must be only on the european export ones then? Does that mean we lowly brits have something you dont? There is a God!! :smokin:
J-Thompson
just south of doucheville
nope
our '03 LTD came with that same pkg.
all I did when I upped the tire size on the KJ was carry a few blocks of wood
under there with the jack
even the TJ cam with that set up
however even the tallest reasonable size bottle jack is challenged
by a 33" tall tire on a 15" rim when flat
That is interesting there Banditsteve. My 04 is bolted under the rear passenger seat and it definitely is a scissor type.
How many ton rating is the one you have for your bottle jack? Does it say? got any pics of it..just curious now.
From the 04 owners manual...
38394[/ATTACH]"]
Ry' N Jen
We carry a cheap 2 ton floor jack year round. It's stuffed in the roof box along
with 2 pieces of lumber (9"X18"-2" thick.)
http://www.princessauto.com/workshop/garage/lifting-devices/jacks/8036709-2-ton-trolley-jack
Don't laugh, the last one I bought from there was in 1983.
And it still works fine!
When we head off road, we also take a 48" Hi-Lift Extreme jack, a Lift mate,
and an off road base.
Check out the link below Tim.
http://www.princessauto.com/workshop/garage/lifting-devices/jacks/list-all?orderby=product_name
None of them come with a case.
But an ammo box might work.
Banditsteve
North Yorkshire. UK
38396[/ATTACH]"]
Not sure of the ratings LibertyTC but I will take some photos for you at the weekend and post them for you. Until then, there are 2 part numbers on there - 52059343AB and 52059412AB. Not sure what they relate to but your local dealer might be able to check them for you. Hope this is of some use and I will post the photos asap. Cheers, Steve :smokin:
Banditsteve
North Yorkshire. UK
38436[/ATTACH]"]
Here you go LibertyTC. Like I said earlier, I am not sure which the correct part number is but the photos show you what it looks like and it looks like it will use the same mounting point as your original scissor jack. Hope this is of some interest to you. Cheers, Steve :smokin:
Thanks..very interesting. Learned something new on those photos.
Got a photo of the top of the jack looking downwards? Is it notched for the frame?
