Is this video accurate for a u joint replacement in my Libby?
dude1116
Pompton Plains, NJ
Yes it is. They're definitely a lot tougher than it looks in the video though. Good luck! It's not a bad job. Just hand pressing them in like this guy does is very unlikely.
Yes harder, he was using brand new , easy slide in, slide out, had them in and out a few times to make it look super simple.
I only watched about 2 minutes and was LMAO!!
I use a vice which is much easier than beating them with a hammer
projectkj
Ontario, Canada
i wouldnt use a hammer to take them out....(if anything to take them out, and bring the new ujoint to a shop to press it in... DO HALF THE WORK AND pay for half
i did mine and used a press.. i mean the hammer is cheap and most people have. If you miss you can damage the drive shaft......
projectkj
Ontario, Canada
at 8:45 you can see he bashes on the drive shaft yoke in order to seat the U-Joint, if you hit to hard you will bend the two yokes together
MantisTobagan
Show Low
Thank you everybody for the replies. I just did mine today and was actually really easy. The video and your guy's answers really helped. Thanks again [emoji3]
