Interior lights
biker69
GREAT BRITAIN
None of the interior lights are working in my car, has anyone any ideas as to where to trace the problem.
I have checked the fuse box under the bonnet/hood but no fuses are blown!
Many thanks in advance.
Leeann
Maryland
I'd check that the stalk switch hasn't been turned off first.
biker69
GREAT BRITAIN
will check that. I take it you mean the dimmer switch on the left stalk (uk r/h drive model) the only reason I mention that is because some things are going to work a bit differently to usa models. Thank you for your help
Just been and checked it but still no interior lights, obviously they all share a common fault, maybe a plug?
Leeann
Maryland
Have you checked the interior fuse block? In US models, when you open the left-hand (driver's) door, pull off the plastic endpiece off the dash and there's the fuse block.
biker69
GREAT BRITAIN
ah, here's me thinking that was just a bit of decoration.
Will get onto that in the morning now(its 23:45 here) and let you know how i get on.
Many thanks leeann
biker69
GREAT BRITAIN
Well, you were right. The fuse box is on the right hand side and the actual 15amp fuse is held in a white plastic carriage unlike the rest of the fuses.
Thanks once again
