Identify and advise
gfunkatoa
Indiana
Wanting to swap out spacer lift for some 927s and 1/4" plate. Did this curent setup eliminate top, iso plates or other parts? Only want to do this once. Just want to make sure I get everything I need before tearing it down.
927s and a 1/4 inch top plate will net you 3 inches of lift
You'll need the stock top mounting plate and stock isolators to use when you install the springs
Hopefully you kept them when you installed the Daystar
also since you've been running a spacer lift check your UBJs since they wreck them
Then also teraflex front bumpstops
gfunkatoa
Indiana
Last owner installed lift. Looks like more to add to the shopping list.
NAPA has them plus I'm sure places like RockAuto as well would have them. Most times the isolator comes wih the top mount, but will have to buy the lower one as well
gfunkatoa
Indiana
Thank you, sir. I was doing some reading and I noticed some Daystar kits had the spacers on thr lower end of the coil. Assuming there is more than one type?
Yours were just installed upside down is all from the way it looks
me!!
canada
ive installed daystar before and that sur is upside down
