I Need Help!!
patbluejeep
ohio
i got the rockfather 2 kit and i am trying to install itright now. i got some srping compressors and the dam things wont come out of the new springs once i have them installed on the struts. what do i do? a local shop wants 45 dollars to use there wall mounted compressor per strut. any ideas?
matthewheld
Pahrump, Nevada (just outside Vegas)
Had the same problem with mine. And that's exactly what I did - used a 2lb hammer and beat them out. Of course, I removed the compressor threaded shaft completely before doing so. Just watch you fingers and toes. You posted a while ago, so I'm assuming you hopefully found a solution.
patbluejeep
ohio
Whew!!! thanks a lot for your help! i actually just got back to check and figured it out in the mean time. its amazing how much you can figure out if you just take 5 minutes and think about your situation. LOL! I just took the threaded part out of the compressors and was able to wiggle the hook parts out of the coils. i actually didnt have to beat anything..... thanks a lot tho. i really appreciate it.
