How to raise the KJ
musicaldoc
Italy
Let's see if I get myself understood.
Where are to be put under the KJ the gummy bricks used to raise cars at the tire service bridge? Are there specific positions for them under the KJ or the KJ is not supposed to be raised in such way?
Thanks
tan's2002kjlimited
Chicago suburb - Hanover Park IL 60133
musicaldoc
Italy
:D :D :D gummy bricks are very tasty :D LOL
Anyway I tried to describe what I see tire servicers use in Italy to lift up a car when servicing it. They put four bricks made of gum under the cars and then they lift the bridge (don't know if in english is called the same way) in order to have the tires and suspensions free while the car is lifted.
Can't find out if the KJ can be lifted the same way or if the frame could be damaged from such procedure.
Atrus
Metro Detroit, MI
Well, I've jacked up the rear and supported the "pseudo-frame" on jack stands. I'd *think* it's OK to do that, but am not certain. I can picture what you're saying, but I am not sure. I miss full frame vehicles!
Corwyyn
Southeast of disorder...
If you're talking about one of these:
I can't see it being a problem. The uni-frame can take the stress of being lifted on four points.
musicaldoc
Italy
Yea, I was talking exactly of such items!!!...but I was not sure if the KJ could stand , like a normal car, the stress of a four points lift.
Thx Corwyyn
The rear axle and the front control arms is where you want to lift. Thats where mine is always lifted when its been lifted like that.
You could also use the area where the jack goes on the front and still use the rear axle for the rear.
or right in front of the rear control arms or I have even brought all four wheels almost all the way off the ground under the ****** cross member
fouros
Gold Coast Australia
if they are using a Hydraulic hoist the KJ will be fine using the rubber Pads to protect the frame when lifting
The KJ is like every other vehical in that respect mate
musicaldoc
Italy
Ok fouros, but where shoud I apply the rubber pads on the frame?
