HOW TO: Change Transfer Case Position Switch
Just replaced mine....probably took 20 mins. It came out and went in super easy, the two difficult parts were transferring the oring and getting the electrical connector back on. The new one is 180deg off, so the connector didn't click on, seemed a bit strained. But the light is off so I'll take it.
Used a standard 1.5" 1/2" drive socket and had it in 4LO.
Dawnmills
Ohio
So I have a problem... The threads on the inside of transfer case are stripped out.. any ideas of how I can redneck engineer this so the actuator will stay in place
nbas
Greece
Just changed the transfer case switch on mine. Thanks for the "how to", it really helped a lot!
It took me 30 mins, and I took my time...
I also changed the transfer case lever bushing with the JL1Kit1.
Now the lever and indication on the dash work fine!
GreyWisent
Possible part number for the seal: 4338956
I'll try to get this and confirm fit. Will post if I end up doing it.
Source: diagrams here for the sensor/switch: https://www.moparpartsgiant.com/parts/mopar-switch-transfer-case~5083138aa.html
@Downtown, thank you for the write-up/how-to! Still useful 10 year later!
P.S.: RockAuto carries both OEM and aftermarket version of this sensor/switch.
Just use the "Part Search" feature with the part number for it (5083138AA).
WVE 1S4129 - $43.99
DORMAN 600555 - $45.99
STANDARD MOTOR PRODUCTS TCA64 - $50.79
MOPAR 5083138AA 5 Position - $94.79
(USD)
DadOSix
Cumberland, MD.
WVE 1S4129 - $43.99
(USD)
I was pressed for time when I did my last one, and did not have the o-ring seal. Found a close match in a kit of o-rings that I bought at harbor freight. Back up and running.
DadOSix
Cumberland, MD.
hello everone, is tehere any 2wd indicator on cluster jeep cherokee liberty 04?
There is nothing on the dash when you are in 2wd. The lamp shows when the transfer case is in other than 2wd. My 06 is a bit different that my 04. But I do think that 04 shows “part-time” when in 4Hi
Seque
Spain
Thanks for all the help and comments from all of you guys, very useful for me. ;-)
