HOW TO: Change Automatic Transmission Fluid
johninva
Virginia
This posting applies to the 42RLE transmission as installed to my 2006 Liberty V6. The heavier-duty 545RFE transmission in the diesel and in some other (?) Liberties is probably different. The cost of the job for the do it yourself mechanic is about $100. This is a pretty straightforward transmission fluid change.
There is another HowTo posting about automatic transmission fluid change, but I believe that one applies to the heavier transmission. I'm not very experienced with Jeeps other than my own, so I'm not sure about all of the applicability details.
To prepare for this job, I'd recommend that you buy 8 quarts of Mopar ATF+4. There are other manufacturers selling ATF+4, but I prefer the factory stuff. This is pretty expensive. I was surprised to find that my local Jeep dealer charged me $9.28 a quart, while the local Chrysler dealer had it at a retail list price of 7.42, and they sold it to me for less with a professional discount.
You'll also need a filter and a pan gasket. I bought the filter at the dealership (though I probably could have bought an equally good one for less at the NAPA store). I bought the gasket at the NAPA store -- you can't buy this at the dealership because the factory installation of the pan is done with RTV sealant, and without a gasket.
You'll also need some thread sealant (I used blue Loctite) for one of the bolts.
You'll need tools to remove and replace the Torx #25 screws for the filter, and the pan bolts which have 10mm heads.
You should not attempt this when the transmission is hot.
To get started, remove the bolts for the transmission pan. Leave two bolts along the back of the pan finger tight, then tap or lightly pry on the pan. When it comes loose, a lot of fluid will drain out of it, so be prepared to catch it. Push the pan back up and remove the last two bolts with your fingers, and lower the pan.
Remove the two Torx #25 screws and pull the filter down from the valve body. There is an o-ring at the filter connection -- remove the o-ring if it was left in place in the valve body. Then install the new filter, using a new o-ring, lubricated in ATF.
Now you have to clean all of that RTV from the pan. You need to take your time and do a good job with this. In every shop I've ever been in, the standard procedure is never to use RTV sealer on an automatic transmission pan, because you don't want any little gobs of that stuff to get up inside the valve body. I have to assume that they use it in the factory to reduce costs, but it's a hassle when you want to change the fluid! Clean the magnet in the bottom of the pan, and make sure that all of the RTV is gone. Wash the pan in solvent and blow it off -- or if you don't have compressed air, use Brake Clean and wipe it clean.
Reinstall the pan, using the gasket (don't use RTV). I used a very small amount of high-tack sealant to stick the gasket to the pan for reassembly (my gasket did not have undersized holes to keep it together). Don't use any sealant between the gasket and the transmission.
The manual I used (AllData) said that one of the bolts needs to be sealed -- it's the second from the front, on the left side. I believe the bolt head should be painted, to indicate which one. I used blue Loctite to seal the threads, though I couldn't really see why this was required.
The manual said to refill with 4 quarts, and then start the engine and fill it the rest of the way while idling. (Of course you fill it through the dipstick tube -- if you don't have a funnel for this get one from any auto parts store. Also slowly move the shift lever between P/R/D.) I had measured what I drained out (at least most of it), and it was just about 6 quarts, so I put in about 5 1/2 quarts before starting the engine. I ended up putting in 7 quarts in all -- now the dipstick reads just under the HOT high mark, after driving the car. As with many cars, the dipstick is hard to read after you've been filling it. Wait while it idles for a few minutes and you'll be able to read it.
The hardest part of this job was cleaning the RTV off of the pan. The most mysterious part was the price difference for the fluid, between the Jeep dealer and the Chrysler dealer.
Another item of interest is that my local Jeep dealer told me that they don't do this job. Instead they do a flush, and they put in an additive with the flush. This is curious, because Technical Service Buletin 26-003-07 (Fluid Flushing Recommendations) says not to flush, and never to use an additive. I have to assume that they do the flush because they make really good money on it. They run 16 quarts of ($10.00) fluid through the system. Also, they don't have to do all of the time-consuming cleaning of the RTV on the pan. They gave me a quote of $280 for the job. I think it's probably better to do a regualr fluid and filter change, as the factory recommends. It's also cheaper.
I hope this is helpful.
John In Virginia
belvedere
SD
Great post, John. The only thing I will add is that the ATF+4 spec is very tightly controlled by Chrysler, so any brand that is licensed as ATF+4 will be nearly identical. I use Valvoline ATF+4, simply because my NAPA carries it, but any brand will work equally as well.
Powerslave
Pittsburgh - Come & Get Me!
67 Belvedere 2-door sedan
57 Belvedere
Wow, too bad I wasn't here last year, I could have got you some AWESOME parts for the 67 car. My brother had a 67 for years, and had to part it out after almost restoring it. the floor was just way to bad, and was not worth the time. Body parts, and mechanical were all good, just the floor was way too gone, from sitting too long, water getting into the garage. He got 250.00 for some parts, then some dude gave him 200.00 to pick the entire car up later...
Austen
Portland, CT
If you filter and fluid change ( which I believe in most) how do you flush the lines to get all of the fluid replaced?
kj924
Prince Edward Island,Canada
I would suggest taking it to a ****** shop, or any shop I guess, they should have a power flusher there that flushes the torque converter along with the transmission.
ShafferNY
Ticonderoga, NY
I paid $300 for the dealer to power flush the transmission, and change both filters in my 45RFE. Would have cost me at least $125 for the fluid and filters, and then only half the fluid would have getting changed.
Great post for those who want to do the job themselves though. Good Job!
flair1111
usa
a flush will be needed to do that. however ive been doing a little something different for a while now that will not flush the system, but over time will keep new fluid going through the ****** over the long haul. i think this is better than just the 30k filter then 5qrt or so change only. unless you have overheated the fluid or some other problem, this should prolong the life of the ****** and maybe avoid a flush. at least thats the ideal anyway.
see what you think. be sure to read the video info for a more detailed explanation. and this can be done as often as you want.
here is the thread, and in the thread is the link to my vid.
http://www.jeepkj.com/forum/showthread.php?t=38025
Austen
Portland, CT
So would you change filter and fluid first or have it flushed first?
dschae1
Texas
I just completed the pan drop and fluid/filter replace on my daughters 2004 Liberty Limited (3.7 V6) and I'm pretty sure it was the 42RLE transmission. It has 69K miles, so I'm a little late getting to this one. Autozone says it should take 5 quarts which matches what came out ( I measured the old fluid by refilling a 5qt oil container) however, it took 6 quarts to get the fluid to show properly on the dipstick. I measured it per the manual when warm and in Park.
Some tips. I didn't have a giant catch pan to keep the mess down, so I used a cardboard shipping box that was bigger than the pan and lined it with a black Hefty bag. I had cut down the box to be about 6" tall. This worked perfectly. Even though it drained toward the rear and over the exhaust cross pipe, there was no spillage beyond the box. I used carb cleaner to remove the oil from the pipe so it wouldn't smoke. I had jacked the car up to replace front Pads and Rotors, but the rear wheels were on the ground. That left plenty of room to get under and deal with the transmission pan. I loosened the bolts about three turns each for the four corners, and removed all the other bolts before prying the pan down. Once it was loose, I let it drain for about 30 minutes, and then for about an hour or two after removing the pan as I had to run an errand. It was still dripping a small amount of fluid even after all this time.
Don't forget to dig out the old o-ring from the filter hole before putting the new filter in. I noticed the filter sits at a slight angle to the valve body which I thought odd, so I took it off and checked it then reinstalled it. There's no way to get it to lay flat, so I figured it is just the way it is supposed to be.
The directions for the rubber pan gasket said not to use any adhesive, so I followed that direction. I hope it doesn't leak ;-)
When done, I simply cut a small hole in the Hefty bag to drain the fluid into the old 5 quart container using a funnel. In case there was more, I had my oil change catch pan near by, but as I said above, only 5 quarts spilled out from the pan and valve body.
Overall, this little project was not as bad as I thought it would be.
Gavinl
Surbiton
Why flush that autotransmission?
How do you know that it is time to change the ATF?
Mine smells like cat's pee to put it politely but it looks clean enough.
What makes this Mopar ATF +4 so special over all other automatic transmission fluids?
TheBlueKJ
South Jersey
Because that's what's required and if you use anything else you will destroy your transmission and need a new one
