How to: Center console removal
Diggerfreek
Colorado
Tools Needed
APPLY THE EMERGENCY BRAKE
First start by removing the rear converter panel from the rear of the center console
Next direct your attention to the shifter/4x4 cover panel
Once the rear of the panel is popped up, pull the panel towards the rear of the jeep
remove screw A
B
And C...There are two screws inside the center console
Once this is done, unzip the brake boot and lift the console from the rear and position like this
When done, installation is the reverse
onlyina
Ohio
I have done this also everything went well but had the hardest time unzipping the e-brake boot.I had to put a piece of wire in the hole part of the zipper and pull that with pliars to undo and still struggled.I was wondering if Chrysler had put something on the zipper to stop it from coming undone involuntarily.
Exalype09
United States
How to Center console removal
What Do I Need To Put An SS Center Console In My Singal cab I know I Need To Change Something On The Dash but No Sure What
