how to break in 4.10 gears on the front axle
hadtomer
Israel
Hello-
about to fit a new set of 4.10 nitro gears to replace my old worn out 2.4 gears.
of course -I know there is a break in period and i should be very careful about how i drive for 500 miles etc- but i wanted to know- should i do it in 4Wd?
I know the pinion gears on the front diff spin all the time even in 2wd- but i want to make sure the front diff gets a proper break in period-same as the 8.25 on the rear-so it will not fail when i will eventually go offroading when the break in period will be over.
p"s-
i have select trac so i can drive on the street in 4wd.
J33Pfan
NY
I didnt know you could change the gear ratio in the front. Did you change the transfer case gearing as well?
As far as breaking it in, IMO: drive as usual except no speeding or very long trips for a while.
Some will put a new axle in and forget about the rest! Just Drive it like they stole it!!
J33Pfan , Yes you can regear the front
No you do not have to change anything in the transfer case ( why would you ? )
tomer Break in, drive enough to warm up the gears, stop let them cool off , do it again etc No hard pulls , no long drives . I always put in 4x4 , then out etc
J33Pfan
NY
I thought front & rear had to be matched up correctly to prevent issues.
J33Pfan
NY
wow look what Sirri found
NEW GEAR BREAK-IN PROCEDURE
New gear sets MUST be broken in correctly to prevent damage. Not following proper break-in procedures will lead to overloading and overheating the ring and pinion as well as breaking down and ruining the gear oil. Not following proper break-in procedures can be determined during inspection and will void the warranty.
Please follow the below guidelines to ensure a proper break-in and long life of your gears.
• Only use high quality gear oils. ECGS recommends Lucas non-synthetic 85W-140
• On initial run, drive lightly for 15 to 20 minutes then stop to allow differential to cool completely for 20 to 25 minutes.
• Avoid towing and heavy acceleration, as well as vary speeds every 5 to 10 minutes while driving on highways.
• Drive conservatively and do not drive more than 50 miles at a time without allowing a cool cycle during the first 500 miles following installation.
• After completing initial break-in, change gear oil at 500 miles. Small metal particles are normal and gear oil will typically be black. Excessive metal in gear oil should be reviewed by a competent differential mechanic to ensure safety of internal parts.
Post gear oil change and initial break-in: Towing.
• First time towing should be limited to light load for no more than 15 miles, then allow differential to cool completely for 20 to 25 minutes.
• Repeat this procedure for first 45 miles of towing for full break-in of gears for towing vehicles.
PREMATURE OVERLOADING AND IMPROPER BREAK-IN WILL CAUSE GEAR OIL BREAKDOWN AND MAY RESULT IN RING AND PINION FAILURE VOIDING THE GEAR WARRANTY!
https://eastcoastgearsupply.com/ft-1479-new-gear-break-in-procedure.html
https://www.youtube.com/watch?v=LeEttxH29sQ
Myke
USA
OP has a 4cyl and already has 4.10s front and rear.
hadtomer
Israel
Just as i wrote- I know how to break the gears in. my question was should i do it in 4WD.
Anyway-thanx Tom i am gonna do it in 4WD just to make sure.
J33Pfan
NY
Hello-
p"s-
GREAT POST! And all the way from Israel!! :happy107:
Gotta Love this Forum!!! :winner_first_h4h:
Stupid question but does this mean that all new KJs fresh off the assembly line went through this break-in procedure?
No of course not, but the majority do not hook a fully loaded trailer to a brand new KJ , run over 5 hours before stopping like I did. But of course it did have almost a hundred miles on it by the time it was delivered to me. :happy175:
Fired
Every new car I have ever owned had the oil changed at 1,000 miles. (Then every 3,000 miles after that.)
I would do the same thing with a new differential, though not as often with the subsequent changes.
