how do you change trans fluid and filter
gabegt90
Damascus maryland
how do you change the trans filter and fluid also what fluid does it take does it take regular mercon thanks guys
Remove the ****** pan bolts and carefully drop pan(lots of ATF will spill out,about 4-5qts so have big drip pan ready),the filters(one main filter,and one cooler line filter,looks like a regular oil filter) are easy,the cooler line filter is a screw on filter like a oil filter,the other has a retaining screw.Make sure you remove the main sump filter o-ring from the ****** and fully install a new one before reinstalling the new filter.Clean the ****** pan,put a bead of good RTV(ultra grey or ultra copper) and reinstall the ****** pan.Let the RTV set for a hour then add 5qts(since you have the 45RFE) and start the KJ.Let run for a few min and run through the gears and check the fliuld level,add as nesecary.The ****** takes ATF+4 only(you may use Amsoil ATF but that's the only alternitive),Valvoline has it now and can get at auto stores.DO NOT USE ATF+3 OR DEXIII!!!!!!!!!!! Bu the way you have a '02 KJ,there is no such thing as a '01 KJ.Good luck.
