loves_off_roading
Well even if you turn "ESP off" it's only gona be partly off. No matter what you do the traction control limited slip will always be on. Thats what is doing the braking and is causing that.
i checked it, tried it, had problems, check your pmI believe that's the one you pull.
I dunno man, I hit bumps and stuff with it on, and I can feel the brakes engage to stop the wheel spin ( I need new struts and shocks, and my tires are at 52Lbs), I LOSE traction. When I hit the button on the column, it doesn't do that anymore, so there has to be something else, for actual TRACTION control? All my pet peeves with the system are elevated when I turn that off on the column.
Check your PM, I got something there for you to look at.
also, i hear the newer ones have downhill assist that you can use in 4low. sounds intriguing when it was explained to me
Agreed. I understand the concept and can mess with them and get them going, but carbs are a pain. I hate tuning the twin SU's I have on my '68.
Why on God's green earth would you run 52 psi in A: a tire that maxes at 44psi, and B: on a stock vehicle?
Guaranteeing that's 95% of your problem there. Drop the pressure to something more realistic.
Twin SU's on what???
I bought a carb synchronizer in the UK which works pretty good.
That and a mechanics stethoscope.
http://www.empius.com/2009_catalog/empi2009_pg100.html
(Bottom of page)
Your right though, SU's can be a real pain to tune!
Yes Daddy, I will change the tire pressure; NOT.
even with mud tires, the places i go, i need to spin the mud out of the lugs to clear the tread for more traction. a mud tire full of clay that you can't throw out is pretty much the same as a street tire full of clay, just round and smooth. get the tire spinning, and the mud comes out, allowing you to take more bites at the mud. also, sometimes i need velocity to keep my momenton up running through this mud, if it's applying brakes, i'm losing velocity and wheel speed... i should just put arb air lockers in both ends, but that is a lot of money, gonna try unplugging for those situations. and see how that works, but i don't have to for about 6 months or so... everything is frozen here now, and by then i will have the mud tires i'm after
haha
dont make me laugh
you are from where? and you are going to tell me about mud?
you see when 1 tire starts to spin the TC kicks in and breaks that tire
sending more power to the other wheel
which works ok with open diffs and under the right conditions will pull you along on 2 wheels ,1 driver and 1 passenger, in fact I wish I had the video of our demonstration of how the ESP/TC works on the near $40K CRD WK
that in bone stock form walked where a TJ with a lift and 33's could not go
now it was built to show off on but still TC works
but with TT's you would have no need for lockers and the TC would be happy
your wallet would be happy and the Jeep would go better
add some tires and you are done ,some what
well... where to start... oh yeah, you are proud of your state, and you think your mud is better than everyone elses mud... we wheel different... I enjoy mud on my roof and windows sometimes. I am not going to sit here and try to compare mud with you. what i am saying is... I have had 34" swampers burried in mud here, no tire visible. my wheel spin got me burried yes, but this stuff was also bottomless, TC wouldn't have helped, cuz the rig sunk, at least it was tall enough to keep the chassis from being totally mired down in it. I have had those tires packed with clay, and street tires packed with clay. a nice shot on the throttle, no clay... can steer and get traction again...
I didn't say i wanted to run fully locked... i am aware of steering issues... I bet we have a lot more snow than you do, our 4x4 club loves to play in it, some of them are fully locked. I said ARB air lockers... you know, the kind you can disengage and go back to being an open dif... you did know that right? and if i did have both axles locked... solid, like the ARBs would do... If one wheel spins, it stands to reason that all 4 would spin, correct? if all 4 spun, the TC wouldn't know I wasn't moving, as it uses wheel speed to sense this, not RADAR. So, the result would be mud or snow flying all over the place... and a big grin on my face.
Now, I am gonna say it easy... I was in an uphill situation, tires broke loose, brake applied. momentum went away, I was trying to steer the jeep away from a tree, and apply throttle to get the tires to dig in. hit throttle, rev limiter, brake action... no wheel speed, the wheel slowed down, the rig slowed down. i came to a stop in mud I should have been able to power through, and have powered through with similar tires on similar sized vehicle without TC. Yeah, I could have slowed down instead of tried to speed up, but when you are going about 3-5 mph in mud uphill, any slower may result in going backwards.
This system is great for everything else I have encountered. This vehicle and it's systems were not designed for much beyond being a soccer dad, who has to go the mall, and maybe head up to the ski resort. It does what it was designed to do. I am asking it to go beyond it's limits. It will get a locker in the rear. if it's locked, and i get one tire on ice, that tire won't spin faster than the other, so the brake won't engage, so, the locker will in effect be helping out. and might prolong the life of my brakes right? probably not by much
Tires are in the future... but so is the lift, and the locker too... and, then come up here and show me how to drive in the snow... lol... bring some of your mud with you too!
