Hi, my name is Shua...
ish_master
SE Alaska
...and I like spending money.
That being said. I joined because I am looking at lifting my 2005 KJ LTD, and figured I could find a resident expert on the forums. A fellow by the name of tommudd has certainly delivered.
I have decided to go with the tommudd OME 927/948 and Bilstein special (he should seriously get some kick backs from both companies). I decided to lift it as it's time for new springs/shocks, so why not have a little fun as well. This will be my first lift, so I am rather excited for this adventure.
Odometer is reading 66,770mi.
Current issues that I am facing on the KJ:
- Right rear axle seal has sprung a leak. I just noticed that while replacing my parking brake shoes. Timken bearings and seals and a LubeLocker gasket have already been ordered up. (might as well since I'll have her opened up.
- Horrendous noise/vibration coming from the front end. My guess (hope, least it be something more expensive) is that it's the intermediate shaft/CV connection. I jacked it up yesterday and heard some good crunching while checking the play on the passenger side CV. She's headed into the shop tomorrow morning to get some more info.
- While I was down there I decided to poke around (always a terrible choice), and I found that the driver's side TRE has some slop, so I ordered up new MOOG replacements (might as well do both, right?) from RA.
Recent Maintenance:
Transmission fluid/filter change - Just completed last night with LubeLocker gasket. No drips so far. Usual metal shavings on the magnet; no chunks.
Spark Plugs - Just completed three weeks ago. Pretty sure it was their first change. Largest gap was .074. It no longer sounds like a diesel.
Oil/filter change - Always Mobile1 Full synth 0-W30.
Future Maintenance:
U-joints - Spicers on hand just in case.
Wheel hub assemblies - Timkens on order just in case
Diffs and T-Case fluid changes.
I think that that's pretty much it for me. Thanks for having me, and I look forward to chatting in the forums!
Recent Maintenance:
Future Maintenance:
Welcome to JeepKJ
Kick backs.......would be really nice :happy175:Could afford to do more to mine then!!:icon_razz:
Low mileage should be in good shape
If you want some advice on the lift, I'll give ya some extra " no charge " :gr_grin:
Welcome Shua. Glad we are helping you here.
ish_master
SE Alaska
Tommudd - thank you very much! And I'll endorse you for those kickbacks if you need! Haha. I will definitely take you up on that offer if I come across something that I cannot find in the wealth of knowledge in the forums. The parts list that you've posted several times is rather comprehensive. So I have a very good starting point.
Dave, thank you! Hopefully I can be around long enough to return the favor.
Side note - I should have joined weeks ago just for the ease of searching!
Jo6pak
Left coast of WI
Welcome aboard Shua.
It's a great forum here, full of good info and friendly folks (some might be a bit too friendly:gr_grin:)
ish_master
SE Alaska
Thank you Jo6pak and renegade 04!
There's definitely a wealth of information on here, and I'm loving it! I've found all sorts of new was to spend money.
I'm going to post over in the members' journal to keep track of the new project.
