metalmoto
I was all set to replace the rear brakes on my "02" this weekend. Got everything I thought I would need. New brake shoes, and hardware kit. But I was not expecting to find them so very rusty, and it appears they were not working at all! The drum came off easily. But the first thing I noticed, was the starwheel adjuster was rusted and seized solid! A quick check on the internet, and no auto parts store nearby has this part. "Not Available", are you kidding me? So I without removing anything else. I pulled the adjuster out, and had it soaking in kroil (penetrating oil) overnight. With some fighting, I was able to get the screw side loose and apart. But the other end, was rusted solid! Knowing that I need the Jeep to get me to work on Tuesday. I decided to put the seized adjuster back in, until I can locate a replacement. But now I can't get the drum back on, with the adjuster installed! What happened? What did I do to cause this? I tried pushing the pistons back into the brake cylinder. But they wont move. I don't want to take the old brakes off yet. Just want to put it back together, and tackle it again, when I get new brake adjusters. Please help ASAP! Is it safe to drive without the brake adjuster in place? It's snowing outside here now... Thanks in advance!
