Help me decide
mx3_ryder
troy VT
I'm going to purchase a set of cooper discoverer at3 tires but undecided on size. Thought maybe since I'm not doing a mud terrain tire I might go up to 265/70/16 or should I go with a 245/75/16? Also my original plan was cragar soft 8's but am now looking to purchase d windows instead. What do you all think on tire size and which wheel, soft 8 or d window in a 16x7 of course.
mx3_ryder
troy VT
3 inch OME/Bilstein lift
22 inches center of hub to bottom of flare on all four corners
Basically the same height, 70 series just a bit wider is all
either would work well
Check ply rating on both first
mx3_ryder
troy VT
Do all the d window wheels have blue and red stripe? That might be a deal breaker for me as I want an all black wheel.
mx3_ryder
troy VT
Black Rock, maybe? Only thing is it looks like their D windows only come in a 4" backspacing. Wonder if that would cause issues. Likely would stick the tires out too far.
Black Rock Type D Series 942 : Black Rock
942671240 16x7 5x4.5 0 4 33 3.300 1700 132712BR 232712BR
Black Rock Series 942 Type D Matte Black Wheels 942671240 - Free Shipping on Orders Over $99 at Summit Racing
These are exactly what i'm looking for. Love the matte black finish with matching center caps and what do you know, no stripes.
Thanks man!!
Cragar Wheels 942581237 - Black Rock Series 942 Type D Steel Wheel in Matte Black for Jeep® Vehicles with 5x4.5 Bolt Pattern - Quadratec
HoltzKJ
Idaho
Height would be good I run those tires on what i believe is stock, (I bought it this way) and has no rub.
mx3_ryder
troy VT
Just noticed summit racing includes center caps as well as free shipping and no oversized fees making it the best price I've found around.
mx3_ryder
troy VT
What size tire you running? Should post some pics. Not sure if your stock, measure from center of hub to bottom of flare and tell us what ya got. 19 inches is stock height .
When lifted ......7 inch wide and 4 inches of backspacing works great
sits the tire right out to the edge of the flares
that size wheel, 245-75-16s and good to go on a lifted KJ
later on regear
that size wheel would look like this on the outside ( flare) , these are 8 inch wide 5 inches of back spacing but come out the same amount
