streetglideok
How come? What did you guys find or not find? When you have a no start, remember you need 4 things to make it run. Air, got plenty of that, fuel(fuel pressure, and fuel delivery), compression, and ignition. Miss one of those, and no go. If you got fuel pressure, then you can rule out the pump. Does it have spark at the coil? Check compression, all cylinders to be safe. If it still dont start, see if the injectors are working. One of those has to be missing if it wont run.
