Liberty02sport
Stopped at a gas station to fill up the jeep and turned off the AC then shut it down to pump the gas. Went to start it back up and it ran rough for just a few seconds then died (??)Been having some problems with rough idle here lately but I thought i had cured that by cleaning the throttle body and IAC. The Jeep was running fine until I put more gas in it then it just didn't want to start and run, had to be towed home. . It turns over and wants to start and when I turn on the key you can hear the fuel pump come on, but it just won't start and run. ANY ideas, hints, tips, tricks, voodoo, etc would be appreciated. Thanks.
UPDATE: Faulty fuel injector driver in the PCM for cylinder #5 and a bad oxy. sensor. Total cost to fix $900
