fasto82 said:
My amp is the Mmats D100 i believe is the model number. Its a one channel class d competition sub amp.
I am having a lot of troubel locating accurate information on that amp. It seems that the company has fallen off the map, or just has no website. I know of it and have seen them (little white one I believe), but I cannot tell if the RMS rating of 600W is rated at 14.4V or 12V, only CES certified amps are rated at 12V, many companies tend to inflate their values by rating at 14.4V.
Assuming your drivers are both the DVC at 4 Ohms models from below, you could squeeze the full 600Watts from it wiring them all in parallel, and maybe a few more on a burp.
fasto82 said:
My subs are 2 12 inch Memphis M-Class subs.
These are the M1-12" Memphis drivers and at 300rms I would assume they are the ones you used. I do not believe that in any situation with an off-the-shelf box these could hit the 140 mark.
Memphis makes really good quality subs but with 300 watts going into each one, its just not likely.
I am not saying you didnt do it. But Some people have a tendancy to unknowingly increases the numbers they have gained over time, unless of course they have a trophy or photo or some other piece of evidence to remind them of the correct number.
fasto82 said:
Just remember 1 15" sub doesnt always beat out 2 12's.
I did not claim that 1 15" will always beat anything, you are insinuating that on your own. Mine will beat 90% of the 2 12" combos out there but if someone were to pull up with 2 w7 12's I would get b-slapped across a parking lot(provided they were in a custom box). Also 2 12"L7s in a good box could smoke me. Increasing the amount of drivers only amounts to minimal SPL increases. The extra cone area moving is nice and helps alot, but it also means you need lots more power to push them all the way. On that note most people can beat 2 12s with a single 12 of the same model when putting it into a custom enclosure and running it with the right amount of power(provided the 2 12's are not in a custom box also).
fasto82 said:
i know someone who has a 10" alpine sub and i can't remember the amp but he designed his own box and is able to achieve 150+ dB. it's unbelievable, but very true.
As long as its this one and he had a box built specifically for it and put a 3000watt amp on it, I would have no problem believing it. In the same sense the 10" solox would score WAY WAY higher than even that alpine 10"
fasto82 said:
Now where exactly did you place the mic? on top of the passenger side dash? i cant remember 100% but i believe that's the place to put the mic in order to get the best SPL readings.
Its on the center of the dash. As far as a "Best place" to put the mic, there isnt one, because the dynamics of every vehicle are different. In my case, I had just bought it and slapped it right on the center because that was to easiest place to put it.
In competition class systems the locations of the mic is predetermined by the official judges and the high class builders engineer the box and surrounding materials to guide as much spl to the mic location as possible.
fasto82 said:
and also in the video you never reset the meter before your last run like you did before the 2nd one. don't you need to reset it in order for it to take a new reading? if so you could've gotten a higher reading and not know it from that clip.
While in "max" mode the meter will continuously test the SPL and if it reaches an amount higher than the one listed it will display it and hold it. It does not need to be reset. The reason I changed it midway is because while in AVG mode it only displays an instantaneous average and doesn't hold a number for you to see after.
fasto82 said:
and don't forget to take into account every meter has a margin of error of +or- 1-2dB.
That is not true. The margin of error is much more variable than that, and temperature and humidity also need to be accounted for.
The term-lab ($1500+, and the one used at all competitions) is the only meter that can claim to have an accuracy within 1-2 db all other meters depending on quality increase that range. The meter I used is supposedly deathly close to the termlab.
