Going a little higher after OME/Bilstein lift?
vader361
I have a 2010 KK with an OME/Bilstein lift and it's at 21 in. Front and rear. When I haul people I get some rubbing. If I add two isolators each side in the rear I should get another inch? Will i need an adjustable track bar? Can I use the stock sway bars? In the front I am gonna get aftermarket control arms and a 1/4 inch top plate and do a clevis lift to make it level. Will th CV joints be be ok? Is there anything else that could be a problem?
Just hangin' out.
What size tires/wheels you running? Hard to tell from your profile pic, but I am guessing larger than stock?
Dave_too
I don't remember asking why it's rubbing.
I think Johnny O's response was to this question of yours:
"Is there anything else that could be a problem?"
No point in being rude to folks on here.
