After doing much reading on here and over at LOST I decided to install OME 927/948 per most members suggestions. Got the lift installed Saturday and immediately loved the look of the jeep! However the ride left a little to be desired. I don't mind a rough riding (mild) but I noticed I had absolutely no up travel (compression) in the front suspension. In other words I could put the jack under the front a-arm and it would lift te jeep into the air without compressing. Is this normal? I figure it is a result of the higher spring rate (400 vs 310 lbs/in) and the 1.5" longer spring that must be compressed to fit in the strut ....
I am lost right now because I was hoping to get a little higher for new tires but did not want to lose my handling when hitting potholes and such in the road.
Can anyone help?
Can anyone help?
