Front proprller shaft bursted...
m_volyrakis
Greece
I have been hearing some sort of clanging metal noise for quite some time now and finally got time to visit a garage.
Front propeller shaft on the differential's side had bursted.
The guy at the garage (former Chrysler mechanic) quoted 900 € for a brand new one.
According to what he said I have to change the entire axle since it can't be repaired.
Local mechanic told me he can fix it for 80 €
Whom should I trust? Any ideas?
Started looking around for a used one mine is a 05 2,4L 4,10 will a shaft from a 3,7 3,73 fit?
Corwyyn
Southeast of disorder...
I had mine go out a couple of years back; went and found a used one for $90 (around 150 euros), put it in and have had no problems so far. Not sure on the fitment for a 2.4L but they shouldn't be too outrageous. Good luck with the search.
m_volyrakis
Greece
Thanks for the replies guys !
Do you think this is normal? My car has 60.000 Kms on it.
Normal? No.. Does it happen more than it should.. Yes... :)
Youre not the only one.. Although this is the first Ive seen that actually failed.. Usually they just make a bunch of noise but Ive not seen the cv actually come apart like that.. Sure its happened though..
m_volyrakis
Greece
Can someone give me the part no. for an export 2005 2.4L Eng(ED1)/6SPD M/T NSG370(DEH) Liberty sport with VIN 1J4G6C8135W674993?
All the parts lists I have don't include the part number for 2.4L (ED1) engines.
fouros
Gold Coast Australia
the seal broke on mine a few years ago and the uni got full of mud and rocks , they are rebuildable
J-Thompson
just south of doucheville
you may be better off going to a salvage yard/yards and getting the parts from other Jeeps to convert to a U-joint style shaft
you need the front out put from a matching T-case
a yoke from a dana 30 and the drive shaft from what ever you can that has the proper U-joints to match the yoke and the T-case
This is one of the things I plan to do if/when the front shaft on the KJ goes
