Front Bumper Cross Member Replacement Question...
NoVA_KJ
Arlington, VA
So I rear ended someone on the highway last week when someone cut off the person in front of me. I was going around 15-20 mph on impact. Bent the front cross member pretty good causing the grill to hang loose, the gap between the hood and the front quarter panel to get wider towards the front, and the gaps between the front doors and the quarter panel to get narrower towards the bottom. My alignment seems to be ok; pulls slightly to the right, but that was happening before the accident.
I plan on getting an estimate tomorrow from a few body shops, but I wanted to get some input on here as well. I've got pics attached below. In order: front cross-member L (2x angles) & R sides. Is this a part that's easily removed and reassembled? Do you think the original part can be reshaped? Thanks!
Needs to go to a body shop to be put on a frame machine so everything is aligned correctly
pictures ??????
