Front axle nut socket size
eradicator006
Canada
Today I just discovered that my front driver's side axle seal is leaking. I saw a drop of oil on the driveway and upon further inspection it appears to be the axle seal.
What size is the axle nut? I am finding 2 different sizes on the internet; 35mm and 36mm. I hope it is 36 because I cannot find a 35 locally for purchase.
Thank you.
eradicator006
Canada
Well darn. I think I'll just take it in to get done then. Was quoted an hour which isn't too costly. I do need to buy the seal from the dealer. It seems nobody else can get it. Is there anything else in addition to the seal that I should get? Bearing, bushing or what ever it is called?
Thanks
4x4kayak2112
tx
Ive heard that a 36mm will work on a 35mm.......YMMV
Mines a 35mm
Sent with the power of children's screams!!!
02blue
Thanks
I personally wouldn't go changing anything else unless you have a symptom. If you have the shop do it, and you trust them, tell them to check things over carefully.
My philosophy has always been if it ain't broke don't fix it. Of course I've been known to break things while trying to fix them too. :shrug:
CactusJacked
Chicago Suburbs
Yes, it's a 35mm but a 36mm will work just fine, and won't round anything off. That's what I had in my toolbox from my old VW days, not an issue.
02blue
I haven't tried a 36mm although I have one for a different vehicle but I'd definitely trust CactusJacked and go for it. I know the hex design of my 36 shouldn't round anything off on a 35 nut.
Not sure what the options are in Canada but I think they carry the 35mm at quite a few parts places around here. Maybe order one from NAPA or PepBoys.
TheBlueKJ
South Jersey
I used a 36mm as well youll be good
Sent from my iPhone using the power of children's laughter
35mm is a common GM FWD car axle nut size also,there dime a dozen around here at any autoparts store.Some aftermarket CV's come with a 36mm axle nut for the KJ but OE is 35mm.
If you use a 36mm socket make damn sure it's a 6 point socket and do not use a impact.The torque is 175lbs-ft.
Leeann
Maryland
All my local autoparts places have 35 and 36mm sockets - Advanced Auto, Pep Boys, Autozone, NAPA...
I have both in my toy chest, but 35mm is what fits better.
