Found unplugged under hood.
gerG
Southwest Fl.
Was messing around under the hood and found this not plugged into anything. Didn't see anywhere obvious for it to go. Has a black wire with white stripe and a brown wire with tan stripe. It's located on the passenger side of the engine compartment. 2002 3.7 automatic Limited. Any ideas what it goes to?
Connects to your washer fluid tank.
notes:
I used file: 2006-KJ-SM.pdf
searched for 'BR/TN' came up with a listing for LOW WASHER FLUID SENSE on page 8W-80-45
searched on 'washer fluid sense' and came up with SWITCH-WASHER FLUID LEVEL - 2 WAY on page 8W-80-109
finally went to 8W-53 WIPERS and found page 8W-53-5
now if only i had a PDF of the FSM for the 2007 MY I'd be golden. ******* drive by wire system.
