Somebody here on this Site recently posted a picture and part number of a non-OEM Multifunction switch which works well at a good price....I cannot at this stage find that post.
If a new assembly or bone-yard assembly cannot be sourced then the worst case scenario is that you fit a separate switch to turn on the Fog Lights!
Give us the wire colors in the plug that you assume is for the Fog Lamps....should be solid colors or a solid color with another color stripe. We can then check the wiring diagrams to see if this harness is indeed for the Fog Lamps.
You can do a search on the Home Page for multifunction
There are a fair amount of hits there!
