Flow rate of injectors Liberty 05 V6 3.7
Adcoski
Hello
Does anyone know the flow rate of injectors for a Liberty 05 3.7 V6 and also their resistance in OHM?
My KJ is equipped with the NGC PowerTrain Control Module, so the fuel pressure is 58psi (400kpa).
Thanks
Adcoski
Thank you, I already have this documentation for the KJ05 but unfortunately it does not indicate any value for the injectors.
There are many compatible injectors, I believe that those of origin are given for 20lbs/hour but at a pressure of 43.5psi (3 bars) or the kJ of 05 have a fuel pressure of 58psi (4 bars) I suppose so that the injectors have a flow rate of 23 lbs/hour, but I am not sure of that.
For resistance it seems to be 12 ohms.
