Finally got the Transfer Case Fluid Changed
brucebotti
South Windsor, CT
I had trouble before trying to change the fluid in my transfer case. Thankfully I had heeded the advice given here and had tried to take off the fill plug first. Despite my best efforts, I ended up stripping head of the plug. Today I took an old 10mm allen key and tack welded it to the plug. After hosing it down with PB blaster, it came right out, with the use of a pipe on the allen key. Hopefully the picture I took is shown below. I thought of reusing the plug with the allen key attached, but decided to go with a new plug from NAPA that allows you to use a 19mm wrench to remove it.
Bruce
jnaut
Seattle
You know, that's pretty slick. Had I stripped out the bolt, I'd have probably cussed up a blue streak, then taken to a shop. But tack welding a tool in there, even if temporarily is an awesome idea.
Powerslave
Pittsburgh - Come & Get Me!
I am so glad mine came right out with the socket w/allen on it. I sprayed it with PB Blaster way before attempting it. I use it ALL the time for stuck security screws, and wedge/sleeve anchor bolts. That stuff has very rarely failed me, and I use it religiously. If that doesn't work, I use a torch; though not with these plugs I read. Good stuff that PB Blaster...
brucebotti
South Windsor, CT
Normally PB works for me also. The allen wrench never fit very well into the fill plug, especially compared to the drain plug. Otherwise, I think the PB Blaster would have been successful.
Bruce
