Fel-Pro Or Mopar-Valve Cover Gaskets
Wondering since the Mopar ones seems to leak often, if I would not be better off with the Fel-Pro.
What is the quality like on the fel-pro gaskets?
Recommendations, experienced thoughts appreciated...Thanks!
TwoBobsKJ
Northern Ohio
I used Fel-Pro on mine and they've been fine for 60,000 miles or so.
My 2 cents... :waytogo:
RenKJ
Canada
Fel-pro valve cover gasket here, only 20,000km, doin fine so far
I used Victor Reinz from Rock Auto. That was three years ago and no leaks. Had the passenger side off recently and they looked good and retorqued with no leaks. Guess about 20k on them.
JasonJ
Michigan
My Mopar gaskets lasted about 90,000 miles before the right side started leaking... so while I'm sure they're a fine gasket, I opted for the Fel-Pro set locally. I still haven't put them on yet, however.
I don't think it matters much. I got about 30% off on the Fel-Pro set recently... so I went with that. Plus I've had excellent luck and with permablue gaskets from them in the past.
