C.W.
Although I originally posted this list in the faq to double check myself for my first big fluids change, I thought that it might be a good idea to get everyone's favorite fluids to use and why. Information on how much to use and what general type is easy to find, but brand specifics (or favorites, if you will) is not. Please indulge. This is what I'm doing (total newb):
2005 RENEGADE (not limited slip, 6 spd manual, command-trac)
Air Filter:
AMSOIL Ea Air Filter EAA201-EA
PCV Valve
FRAM Part # FV408
Spark Plug
Autolite Ignition XP5224
Oil & Filter
Mobil 1 Truck & SUV 5W-30 /Mobil 1 Extended Performance Oil Filter
Front & Rear Axle Gear Fluid
Mobil1 Gear Oil: 75W140 Synthetic
Power Steering Fluid
Mopar Power Steering Fluid
NV231 (Command Trac) Transfer Case Fluid/Filter
Valvoline ATF +4
NSG370 Transmission Fluid (no filter)
Amsoil Synthetic Manual Synchromesh Transmission Fluid (MTF)
Brake fluid
Valvoline Synthetic Dot 3&4
Serpentine belt
Goodyear Gatorback
2005 LIMITED (auto, select-trac)
Air Filter
PCV Valve
FRAM Part # FV408
Spark Plug
Oil & Filter
NV231 (Select Trac) Transfer Case Fluid/Filter
Valvoline ATF +4
42RLE Transmission Fluid/Filter
Valvoline ATF +4
Brake fluid
Serpentine belt
Goodyear Gatorback
Plus Zerex G-05 coolant, although I've asked at auto parts stores, which I cannot find and apparently it cannot be ordered. Might have to check the dealer, ugh.
Air Filter:
PCV Valve
FRAM Part # FV408
Spark Plug
Oil & Filter
Valvoline ATF +4
Brake fluid
Serpentine belt
Goodyear Gatorback
Air Filter
PCV Valve
FRAM Part # FV408
Spark Plug
Oil & Filter
Valvoline ATF +4
Valvoline ATF +4
Brake fluid
Serpentine belt
Goodyear Gatorback
