TigerClaws
I have a 2004 Libby i bought last month. As you all know, a jeep owner has to try it....
So i went in the snow to drive it, and of course, i got to the point where snow was rolling down under the front bumper. I did a bout 500 feet in there before i hit somekind of a bump that stopped me and made me get stuck there. When i put it on reverse, to see if i had any freespace to get on reverse, i saw the jeep had stalled... When i went to start it the oil heat light lit up (yeah the red one). So, i let go the ignition and figured id let it rest there and check how bad it was outside (let it cool down). Outside when i got to the front, i had a smell of oil,... , but the jeep's temperature was still in the middle so no engine heating at all. Is there a heat sensor for tansmission or differential that makes the jeep stall to protect it ? Cause im not sure, but i think it lost a bit of engine oil (thus explaining the oil smell). Samething with the coolant, no smell but a yellowish spot in the snow underneath the jeep where i was stuck. I've checkes coolant and oil and cold out, i need to put some. I swear it never went up in heat on the gauge, so im a bit comfused...
