Alright, maybe someone here will know more than Mopar customer service and the 10 dealerships I have dealt with on this question. I have an 06 Limited, meaning I have power doors, keyless entry and Sentry Key. If you install the EVS Base System, it says it is only for vehicles without these features. However, to install the Shock Sensor (Part #4886260AB), it says you have to have the EVS Base System and the dealership claims that having these features does not mean you can install the shock sensor. It also means you can't install the EVS Base System necessary to install the Shock Sensor. Total Catch 22, right? Yet the EVS I, according to them, will not allow you to install the Shock Sensor, either, and there is no Shock Sensor built into the EVS I. So basically, according to them, if you have a Limited, you are Limited in your options as only a vehicle that is poorly equipped can get the EVS Base System and consequently Shock Sensor. How on earth can I be unable to install the Shock Sensor and there be no provision to get one installed?
Ideally, I want to install the EVS I and Shock Sensor on an 06 Limited. Period.
