EVIC question
I have the Limited "G" package, which according to my 05 brochure, should have the TPMS display in the EVIC. It has every other option in Luxury group, and basically all the ones in the G package (no off road pack, no Nav, no bling wheels). The only things relating to the TPMS system that the EVIC displays is "Spare Pressure Low" and "Check TPM System". I can't get it to show the tire pressures though. Am I doing something wrong?
Thanks!
67Customs
North Carolina
I believe they removed this option from the EVIC after '03 or '04. My Limited has everything but NAV and mine doesn't sow the current tire pressures. Just warnings if they are needed.
Mine is an 05 G package and sounds like it is the same as yours. I think 02-04 had a different TPMS in the EVIC? My 05 doesn't display actual psi tire pressure or tell you which tire except for the spare either.
