kj2002vzla
hello fellows...i´m about to rebuild my engine because i have to refill 1 quart every week and a half and i see moderate white/blueish smoke coming out the exhaust, and im gonna change everything to have a 0 km engine, and some mechanic change my oil to 15w40 and im crazy about going back to 10w30...so my question is: is the brand "Sealed power" a good brand to buy piston rings set, main bearing set and rod bearing set? ...thats the only brand i found on amazon ...also im getting: piston rings, rod bearing set, main bearing set, mopar timing chain kit, acdelco water pump, melling oil pump, fel-pro gasket set, acdelco belt tensioner, hayden transmission cooler...any recommendations about the parts im gonna order? thanks a lot guys!!! appreciate it
