Richard Cherkauer
Hello everyone I am new to the forum. I did a few searches before posting but not really having any luck. Just picked up an 02 Liberty for my sons first vehicle and there are some issues I am trying to track down.
Its a 2002 Limited with the 3.7.
Here are the electrical issues we are having.
1. Power Locks Issues
The power door locks only work when the vehicle key is in the "on" position or the vehicle is running. Additionally the back gate will not even open unless the key is in the on position and you hit the unlock switch. Then you can open the back gate. Also the doors will not lock with the power locks. There is no key fob. Its an old school key.
2. None of the lights on the vehicle will work without the key in the "on" position or the vehicle is running. No headlights, dome lights, dash lights, only the hazards will work unless the vehicle is on.
I'm not sure if this is a fuse issue. The fuse #6 on the inside that is labeled for power locks is ok. Not sure if there is a fuse under the hood that might also be bad. The battery is fairly new so that could be it as well.
Just thought I would put this out and see if anyone else had a similar issue with any solution.
Thank you
Thank you
