Ball joints were inspected when I had the front end aligned last month. Shop didn't notice anything worn beyond spec and there were no issues getting the alignment correct. (unlike the idiots at Les Schwab that claimed I would need a caster kit to get the alignment correct) Jeep drives beautifully. Probably the best it ever has.
I have several noises I'm trying to track down actually. One is a squeaky chatterery kind of sound. Similar to the sound two styrofoam coolers make when rubbing together. This noise started after I installed OME 928 springs and Bilstein shocks. It only makes the noise on small bumps that don't cause much suspension articulation. I also get a bumping noise from the front end occasionally that can happen during a turn or while going straight. I don't get the noises going over large bumps, like speed bumps and big potholes. All this strange noises started after I installed OME springs last February. The noises were very subtle at first but have gotten louder. I'm all most to the point of just throwing new parts at the suspension until the noise goes away.
On a positive note, I just moved so my commute went from 100 miles a day to 5 miles a day, so this stuff isn't as big a priority for me. Well, except with my personality, squeaks, rattles, burned out light bulbs and other little things like that, drive me FREAKING NUTS!!!!!!!!!!!!!!!!!!!
