Driving feels different in differenty liberties
RChris173
FL
Driving feels different in different liberties
I have a 2003 KJ and I was recently driving a 2007 KJ today. I noticed that the 2007 KJ had more of a delayed reaction and what felt like a different acceleration.
I can't really describe it other than it just really drives and reacts differently.
Same goes for the steering and braking. It seems like I have to steer harder and brake harder in my 2003 KJ, but in the 2007 KJ I just had to lightly use the brakes and the steering felt much more assisted, especially around tight turns.
Was curious if anyone else noticed these differences between the KJ's or if I'm just crazy. (or if these things can be adjusted on our KJs)
Thx guys!
BigRich201
west new york,nj
Thx guys!
The 07 has ABS which is the reason why the it feels like you don't have to press the brake so hard and throttle by wire I believe which gives you the delayed throttle reaction vs cable throttle and no ABS on the 03.
But...what explains the steering??? Ball joints, perhaps?
number of miles, how its been taken care of, type and size of tires, plus what Troy stated
all of the above will change the way one model handles compared to another, even ones the same year but with above differences
RChris173
FL
Figured that was it. I like the feel of my '03 cause that's what I've been used to anyway haha ... but the more manual control makes it feel like I'm more in control of it.
I guess if I were in a situation that required quick braking and I wasn't prepared, then the ABS could come in handy.
They do have different tire dimensions, maybe tire pressures also are affecting the steering.
The cold weather will drop your tire presssure too and possibly have an effect on driving.
PS........just realized you were in Florida Chris.
dude1116
Pompton Plains, NJ
Truth be told. Same car models of the same year can drive very differently if tires and pressures are different. Mileage probably has a strong effect on it too.
Ry' N Jen
As already pointed out, all Liberty's will drive differently.
Take our '04 KJ compared to LibertyTC's '04 KJ.
both have high quality lift kits. Our's a Frankenlift with Rancho shocks, Tim's OME with Bilstein shocks, both HD Coil springs, both have Goodyear tires...
His Silent Armour our's M/T R Kevlar.
Both have the exact same SpiderTrax 1.25" wheel spacers as well as JBA GEN4.5 upper control arms
Both have added weight added up front. His a pushbar our's a winch and mount...
Both handle and drive totally different!
His softer, our's firmer; both drive very well but totally different!
Oh, and his has 1/3 the milage compared to our's
My Jeep needs new steering bushings and then beat on my heep in some fun tails Ryan.
I think mine is softer valved with the Bilstiens and still a relatively new spring thing.
Too Bad I could not find the ole Rancho's.
Your's is well settled (now way firmer) and those awesome MTR's lead the way in off road prowess and road feel.
Lets put it this way, you can hear Ryan coming down the highway.
42583[/ATTACH]"]
I think it is time to finally get some Lights mounted too!
I really like the Rigid D2's LED ones we were talking about last night.
http://www.rigidindustries.com/D2-p/d2.htm
rockymountain
Spencerville, IN
That's why IMO. Tires make a bigger difference than most think. I have BFG KMs and mine feels like a tank... that handles like a sport truck!!!
Alignment specs have a lot to do with steering feel too. The more caster you have the easier it will be to turn the wheel.
... and EF that damn throttle by wire.
67Customs
North Carolina
My brother's '06 feels different than my '05. Lots of things could be at play. Especially tires and suspension wear.
hyde
Makes me think, do they even make any new vehicles that uses mechanical direct acceleration/gas pedal like we had in my 04 KJ? It seems like everything is drive by wire. (I don't care for the term, I would assume drive by wire should be the direct gas pedal term because our KJ actually had a thin wire going from the gas pedal to the throttle sensor, now that's drive by wire) :)
