Does this have a slight clevis lift...
Moab
Silver Spring
When stock is the clevis fork all the way to the bottom of the Strut?
Here it looks like about 3/8" away or down from the clamp.
Thanks for everyones for the help already - I'm just trying to understand the Liberty suspension and it's limitations.
Moab
Silver Spring
Thanks, can this be adjusted more or is this the safe point?
I mine could I get another 1/4 out of it?
ptsb5a
Northern Alberta, Canada
Personally, I wouldn't pull the clevis down any further than the bottom edge of the shock body. You know, clamping force, area 'n all that stuff. But, to each their own i guess. Someone will tell you that you can easily go further.
ThunderbirdJunkie
Bronze Supporter
Newport, KY
That's got a bit of clevis lift to it, yes. On all shocks ThunderbirdJunkie has seen for the KJ, from the lowliest of KYBs to the OMEs, un-clevis-lifted would have more shock protruding from the bottom.
twack
rochester mn
from that pic it looks like there is no clevis lift and that the clevis is just under the bulge that holds lets you know where to put it
Moab
Silver Spring
Thanks for clearification.
Thanks for everyones patience as I try to figure out the suspension on my truck.
family KJ
JPOTM WINNER
Tampa, Florida
The stock suspensions has that stopper or metal flange(or whatever you want to call it) ...extends about 1/8" out and the top of clevis sits on that. I can not tell from that pic, but if it is not resting on that stop, then it has been lifted.
