Gwantas
When I drive in standard 2 wheel drive, no noise. As soon as I put it 4WD high, I get a real nasty whining noise from the front that sounds like a solid diff that is packing up. Any thoughts on this ?
I hope that you are only engaging 4WD high (or Low) for short distances only on VERY loose sand or very wet mud. Our 2002 2.5 Sport models (I also have one)
has the 4X4 system without a central differential so you can only use 4X4 on loose conditions as described above for short distance at max 80km/h or you will instantly break something as... without a central diff....the front and rear wheels cannot compensate for variances in speed from front to rear wheels.
Read your Owners manual (in glove box) for more information...if you have engaged 4X4 on a firm surface then you have probably broken something by now:disgust:
