- Joined
- Dec 17, 2006
- Messages
- 10,612
- Reaction score
- 43
I use either Royal Purple 75W-140 or Mobil1 75W-140 gear oil,both very good.Whats good oil to be putting in the front and rear diffs? can I use the same one that goes in the transfer case? is Draining the front the same as the back?
You can not use ATF+4 in the diffs.The front diff has a drain plug(8mm allen)and a fill plug,no removal of the diff cover since a diff mount blocks the way.The rear diff you must remove the cover to drain,reseal with RTV and fill using the rubber fill plug on the rear diff cover.
