Diesel Liberty's
MrMopar22
Charlotte, MI
I'm new to the Liberty world; this site has been very insightful, thank you.
I bought an '02 not running because I need something different for pulling a small enclosed trailer we use for ballooning. I got it pretty cheap, thankfully, because it's needed SO much stuff to bring it back to life: Valve spring, A/C condenser, radiator, heater fan resister, exhaust, rear drive shaft, U-joints, and rear axle. Still uses coolant, so probably head gaskets in the near future. But after all that, I fell in love with it and wished I had bought one earlier.
I was really excited when I found they made a diesel version. We do a lot of driving towing a 5X12 enclosed single axle trailer to different balloon events; the liberty and trailer are a great fit together. The down side I've noticed is the poor fuel economy w/ or w/o the trailer, so the diesel sounded better.
I've done some homework, but have a lot of questions about them before I commit to buying one. So hopefully there are folks on here that can help me.
A friend of mine has one so I got to drive it and look it all over, my questions are:
It's claimed to have a 5 speed auto, but no matter how many times I started from a stop, I can only count 4 speeds and a converter locking. When I pushed the O/D off button it runs the same RPM as my 3.7 does at 70. His is a 2005, is there a difference between 05 and 06? Are they really 5 speeds? My main concern is that with the overdrive off it's turning 3200 RPM when you tow.
Who makes the engine? I looked and couldn't find a manufacture name stamped anywhere. What's the longevity on those? Are they a cheaply built high maintenance? Any pump or injector problems?
I heard they have a timing belt issues and parts are big $$$$$ and hard to get. Is that true?
I guess I'm looking for peoples opinion if it will work for what I will primarily use it for, towing a small trailer.
The CRD has the 545RFE which unlocks the 2nd OD via computer softwhere.The same trans you have in your '02(which is the 45RFE) but without the programming to unlock the 2nd OD.
The 2.8 CRD engine is made in Italy by VM,it does have a timing belt and yes parts are very hard to come by.Most are only going to about 100k before a major repair is needed,and not talking about the timing belt change but more in the lines of a turbo or blown engine.Expect a very long wait for a engine at $6000+,about $1500 or so for the turbo.
