Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Welcome to the forum.
Let me try to explain it this way...
The Correct Transmission fluid is ATF+4 and is a warranty approved product for your Jeep.
Why would you want to use a non recommended GM synthetic transmission fluid in your Jeep?
IDK..but if you dont flush that Dex6 out ASAP expect some bad noises, clunks & destruction soon!
I'm assuming this is an automatic trans (not sure what was available in export vehicles). If so, the above posters are correct: only ATF+4 should be used. Any of the brands listed on this link will work just fine: Licensed ATF+4 Brands | Chrysler
Using any other ATF will cause all kinds of issues in Chrysler transmissions. Dex VI is not only a lower viscosity fluid, but most importantly, has less friction modifiers than ATF+4.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
