Marlon_JB2
Kombat Edition Jeep
Yesterday, I stopped by Autozone to pick up 4 lights. One set for ground use, as seen in my signature picture, and 2 other round ones for my ghetto lightbar. I installed the ground driving lamps yesterday in about 2 hours. It came with a full premade wiring harness. Followed all instructions. Here's how it's wired and mounted...
Mounted on the lower bumper. Grounded on the radiator crossmember just like I did on my '04 KJ. Power comes from the fuse box, just like my '04 KJ. This kit includes a relay however, and the switch needs light for its own LEDs. I ran those very small gauge wires to the fusebox with an add-a-fuse... joined with the parking lamps and grounded on a ground panel under the kick panel, where the hood release is located.
Then I started up my Jeep, it took forever, finally started, and ran funny. I get out on the street, it doesn't really want to go over 2000RPM. Pulled over, shut off for 45 seconds, started it back up, ran fine. Filled my tank up. Water in the fuel I'm thinking since I was so low. Ran fine for the rest of the day.
Played with the lights for a bit, aimed them and such. Hopped in the Jeep today to move it away from the garage so I can work on the lightbar. It started just fine. Had to do it again as I was not far enough away, started fine again. Turned it off, then I turned on the radio as I cannot work on the Jeep without music. Got one side mounted, lights too, the radio shuts off while playing Issac Hayes. This is an ultimate offense. I was not pleased. I had the parking lamps on (forgot to turn them off) and was only outside about a half hour. I've done this before with absolutely no problems.
So what gives here? I'll have to PUSH my Jeep all the way out of the backyard to jump it, and if nobody here has ever seen Detroit... we have REALLY LONG DRIVEWAYS. This is going to be a struggle... then I'm gonna have to drive over my own grass in my mom's vehicle to jump the thing. Ugh!
When it was running... yesterday...
