Dana 44 from 79 bronco
Unless you are going to use the Ford factory raduis arms that was also on that same Bronco,no it would not be a good HP44 to use since the wedges can not be cut off and the axle tube on the passenger side is 2 peices.Totally skip if it has 1/4" axle tubes.
The ideal Ford HP44 using Chevy brakes(converted from drum brakes) is ones from '73-'75 F100/F150.If wanting to retain the Ford disc brakes you want a '76-'77 F100/F150 HP44.The drum brake version can be had for cheap,in the area of $150 for a complete axle,the disc brake HP44 runs about 2-3 times that complete in most cases.
